another problem :S, oil leak
jms700
Stirling
after st andrews iv noticed a small oil stain under my car, when i park it some where new i get a new stain about 4cm square within 3 hours. not sure how bad this is. apears to be coming from the drive shaft? just above the clamp where exhasut pipe meats the flexible joint. dont know if its a big deal or not ?
any help appreciated, thanks
Could just be a seal needing replaced. I'd check all the levels to see how bad the leak is as well as where it's coming from - it may not strictly be engine oil, could be a gearbox seal for example. If the leak's bad, you'll need to keep the levels topped up or not drive it unless you want something to go pop.
I had the same with mine, discovered the sump drain plug was slack, tightened it and hey presto
i changed the oil about 3 months ago so il check the sump plug. and have a wee look around the seals. thanks
