Technical Android radio wiring
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
Sopo19
Hi, can anybody tell me how to wire new android radio? I bought iso adapter but pins are allocated in different slots. Aleo wires colours are different. Any suggestions please?
I can help you Sopo19, since I recently installed a Erisin car stereo on my Bravo.
First of all, do you have a Hi-Fi sound system with 2 speakers + 2 tweets in each door and also a subwoofer in the trunk? The wires on ISO connector are exactly the same as mine, so I suspect you have this Hi-Fi system.
The wires from B part (8 wires, top 2 lines on your photo) are just for sound.
The wires from A part are:
  • CAN communication
  • Subwoofer enable (+12V to enable)
  • CAN communication
  • NC
  • Amplifier enable (+12V to enable)
  • NC
  • +12V
  • Ground
So you have to connect 12V to pin 2 and 5, so the sound are enable, but you only need them powered when the ACC (car key) is ON. So, you have to check the new car stereo Pinout, and see what wire is ACC (in my case is wire 13 Red). Then you can take the current from this wire.
If you car stereo doesn't return off with Key (it depends on your Canbus adapter), please let me know and I can suggest you a fix.
Cadabena, besides that, I'm currently having a problem, hope you can give me an advice.
Do your sound system also is Hi-Fi (from factory) with a subwoofer?
The problem I'm facing is that I can't tune the subwoofer. On my Android car stereo, if I put the low freqs on high (on the equalizer), the bass is far away from it's maximum.
Can you tune your bass using the kit you suggested?
  • CAN communication
  • CAN communication
  • NC
  • NC
  • +12V
  • Ground
Hi, thanks for reply. But it looks like you have different speakers amount. I have tweets only on front door and i do not have subwoofer
I'd suggest getting the correct patch lead if you haven't already to make life a million times easier:
Using this, my double DIN was just plug-and-play with the Bravo.
Do you really think i would pay £54 for this kit while my radio cost about £49? Would rather stay with bravo standard radio.
Ok. Só you shouldn't have to connect anything to pins 2 and 5. Just connect CAN and power.
So i've got yellow,black,red and orange. Which is CAN and where should be connected? Which slot ? Sorry maybe it is stupid question but i never connected car radio before lol
You have to have the car radio pinout. Do you have an installation manual?
