Hi. I recently purchased a Multipla from auction. So I know very little about its history. What I do know is that the ABS light stays on after it does the initial test. The ABS Faulty message comes up. After a little bit or research I found out that its possible to test the wheel sensors using a multimeter. So I gave it a shot. From what I understand the sensors should have a resistance of about 1000ohms, and should produce an AC voltage about 70mV when the wheel is turned.
Well my results show two sensors with 6.5Mohms and two with around 400K ohms. I can only assume they are all knackered. Is this likely. Anyone else heard of all four wheel sensors failing?
