Technical ALFA GT KEY ANTENNA RESISTANCE
chrisAgrinio
Hello again.....
i have another question, in an Alfa gt i have problem with key antenna.... i check the immobilizer with im508s and i have B1002 DTC..... antenna problem..... i check it and is ~41 ohms.... test second BSI and antenna, the same results......
any body have idea how much is must be the antennas ohms in this car???(wires are ok....i start the car by make immo off the ecu, but owner asks if can make it back ori...)
thanks.....
