Hello all
I had a small accident , i hit someone and crashed my radiator on my fiat tempra station 1993 a few months ago. I have fixed the damage and replaced the radiator, all looks as new
but the air conditioner electro magnetic clutch does not work
, i checked the small black box above the right front headlight and it had a connector disconnected. I plugged it back but it didn't helped. Actually it really does nothing even if i connect it back or leave it disconnected.
Then i checked the relays inside and fuses but they all are ok. The air conditioner inside fan and controls are working but there is no 12v on the clutch coil wires when i turn the air cond. on. Could it not work because there is low gas pressure ?
Now i am confused, is there any other place in the car where a fuse could affect this or some connector i don't know , i didn't find it in the repair manual :bang:
So if someone have any ideas i would be glad to hear your advice
The other strange thing is that my radiator fan is working for a very short period of time for about 10 sec. and not enough to cool the engine. Therefore the engine is not stable at 90 C and the temp rises up.
Where do i adjust the low and high values and where is the control box or timer that controls the radiator fan ?
And if someone to be so kind and post a proper electrical diagram of the air cond. control , the cooling fan and wiring of that small black box above the head lights i would be very grateful.
Israel is hot place and both the engine cooling and air conditioner are critical to my and my car's survival
BTW my car is a Fiat tempra station 1.6 carb. 1993.
