Advice on bravo display panel
G
G
I'm looking at buying a 1999 fiat bravo but none of the needles (speedometer, petrol gague, revometer) work. How much will this cost to fix, is it a matter of just buying new and fitting myself?
And will this reset the mileometer?
Could be a number of things, from as simple as a fuse 50p to knackered clocks £250+(estimated)...
Have it looked at to see what the problem is, before you buy, they are plenty of good ones out there to find...
The other thing to make sure you get if you buy a Bravo, is to make sure you get the Red Key...(It states in the owners manual that the car MUST be sond with the Red key) otherwise it will cost you about £800 to get a new ECU and keys...
Daz
bravo hgt 147 s reg the instrument panel from fiat fitted (under warranty) £760.00
You can not get the parts seperate
You may have a plug that needs refitting? bad earth etc
good luck Trev
Re: Re:Advice on bravo display panel
I think they were that much!..bloody Fiat rip-off merchants...lol
As you can take the clocks out in about 5 mins, i'm guessing most of that cost is for the part...
Daz
I
853
IMC63
I
M
7K
M
A
1
11K
Angelo
A
