A Alextru New member Joined Mar 3, 2014 Messages 9 Points 4 Mar 4, 2014 #1 Hey folks need ur help again!, my 98 punto 1.2 seems to slightly kick out the back when making left turns only slight kick but u can feel it, I think it may be bushings? But I could be wrong! Any thoughts suggestions? Thanks folks!!
F flisko ` Parked in the garage Written 5 guides Joined Jan 20, 2013 Messages 6,122 Points 1,228 Mar 4, 2014 #2 left turns- driving over holes ? could be rear exhaust box hitting the car-holder is probably broken -needs welding, or bush, if its this bush, u can easily put it on yourself
fingers99 Patron member Parked in the garage Written a guide Joined Mar 20, 2006 Messages 27,743 Points 4,561 Location Liverpool Mar 4, 2014 #3 Could be just about anything, even a wheel bearing. Best bet, get under there with a big pry bar.
Garf Green Goblin Parked in the garage Joined Mar 26, 2006 Messages 160 Points 63 Location Burnley Mar 6, 2014 #4 Sounds like it could be a rear radius arm bearing or rear subsframe bush common fault on mk1's
