The AC on my Marea 1,6 16V Estiva has a malfunction.
When the AC activation key is pressed the LED turns ON and the fan starts on low speed, like it should, but no cooling appears.
I've been looking at the system, but i'm a little unsure what to do
The compressor were replaced by new 1,5 years ago, so it should be OK.
Is it possible by measuring the signals between the 3 stage pressure switch and the ECU, to determine if the system has the correct pressure?
As far as i know it's the ECU that activates the compressor solenoid, if the 3 stage pressure switch and ECU allows it.
Any good ideas that can keep me from paying a service check?
