ABS
ABS
S
Syed
My ABS light is on for a few minutes and will turn off later. This problem occurs quite frequently. The FIAT service center says it is the ABS sensor problem. Can anyone confirm this.
I have an ABS warning light on as well. It started as intermitent but has permanent.
I had the front sensors changed but the problem still exists. Next job is to change the rear sensors.
Sensor problems are known to exist on Bravos.
regrds
Pete
England
Some mechanics say that it could be a wiring problem or not enough power supply to the ABS system for it to function properly. Anyway how much is the ABS sensor cost you ?
Syed
Malaysia
Syed
Malaysia
