ABS fuse keeps blowing
Right, a while back my ABS (not the light) started coming on nearly every time I used the brakes. Sometimes my brake pedal was high and then the brakes weren't very efficient at all, I checked the wheel sensors with FiatECUScan and found n/s/f one gave a fluctuating reading so I dissconnected it and my brakes worked as normal but obviously the light was on.
The plan was to take both the front sensors off to clean and inspect and refit on opposite sides to see if the fault was the sensor itself or maybe something else, but, needless to say, I haven't got that far yet
Anyway since then the ABS have disappeared a couple of times and I've found that the fuse has gone.
Any ideas why this could be? It doesn't happen immidiately when I've dissconnected a sensor etc but a few days later I suddenly have no ABS and the wheels lock up and I slide...
Has anyone experienced this?
