Hi everyone,
im in Sao Paulo, Brasil right now and a friend of mine is havin some really heavy problems with his Tipo and im trying to help him get things straight again.
He told me that since some time the car would just die once in a while. When we took it for a ride today things turned really bad, it only fired up on the 3rd try, and had idle speed was sawing up and down between 700 and 1000 ... after a while it kept steady at 800, sounded good to me. what kinda stumbled me was that the fuel gage was goin really mad, flippin between reserve/empty and the middle all the time.. mileage gage was normal, tho i never saw it back up all the way when driving down a hill and stepping off the pedal, im used to this from all my previous cars, isnt the fiat supposed to do this fuel-cut-out ?
anyways, so the car just started missing on all 4 like mad all out of sudden, died, and crankin and steppin on the gas just gave this sound what i would describe as a very very low spark not enough to get her to fire up.
so well, i took a look under the hood and well i didnt quite get this engine.
it has this weird air filter box which is supposed to have a snorkel on the left side going up (it was missing, as well as the rear wall of the filter box just behind the throttle body) the intake/snorkel thing on the front was there tho, just the hose which is supposed to go on the nipple on the elbow wasnt there and i also didnt get to see where it should go. i strongly guess that the air filter box is not supposed to be open on the end, but i dont know fiat that well yet
, any idea why this would be missing??
so well i disconnected the lambda probe and i got the car to fire up, which kinda puzzles me cos i thought this would be a ignition problem.... then it ran nice for some time (like a car with a disconnected lambda probe, kinda different but not too bad) but after some time the same **** happened again and it just died off really bad and i wasnt able to get it to run again with or without the lambda probe connected, after waiting 10 minutes, crankin the car up and holding it up at 3000 i managed to get back home.. left the car there and took the bus..
so well here are some questions...
is there any common problem related to my symptoms with this model?
it should be a 4cyl, 1.6 liter fuel injected engine, i thought i could make out the following things, 2-valve OHC, timing belt driven, contact-free ignition,
catalysator, lambda probe.
i wasnt able to see any AFM,MAF tho, and the throttle looked kinda carburator-style... didnt see any EFI like that before, just the kind with a fuel rail and 4/6 injectors...
does it just rely on IAT (intake air temparature) for fuel mixture then? wasnt able to make out a MAP either...
any other useful hints?
here goes my theories...
dirt/crap/rust in the tank chunkin up the fuel pump.... (strange behaviour of fuel gage, but then again mileage gage goin all the way to the right contraindicates fuel system malfunction)
ignition problems (plugs, wires?)
electrical problems (common ground points bad?)
plugged up exhaust system due to catalysator broken to pieces (okay thats kinda far-fetched, but roads are REALLY bad here...)
im really lost on this one...
i did search myself a little through the board, and i did see the repair manual, but i thought id ask you guys first cos im on dialup and it takes long to download this whole manual...
thanks in advance fellow fiat drivers!
byebye
simon
byebye
simon
