70mm drop!
70mm drop!
DrSergioDJ
Ok, i'm thinking about a BeBe springs, which go down 70/55mm...any chance of fiting a 205/40/17 tyre? :)
Or should I go with a 195/45/16?
I think you'll struggle with 17's.
It'll need major arch cutting.
Riclemus might be able to help though, he's just fitted 50mm springs on his HGT with 17's.
and here i am
i got 50mm gmax springs in my bravo hgt (wider arches than standard bravo). i have only got the front ones in but they fit perfectly, no arch rubbing at all and i still get sull lock on the steering. the back ones will need a bit of arch rolling but thats nothing a hammer cant sort out! beware spring compressors if ure fitting them ureself because i nearly broke my fingers when a compressor exploded from full compression taking my hand and knee with it. care is not a joke! seriously tho i wouldnt go lower than 50mm. my ride now is ****, the engine plastic guard scrapes on everything and i cant even look at a track or lane, pebbles in the road scrape. all manner of crap gets stuck in the engine bay. u get the idea. i have a set of 35mm springs as well so i might put them in the rear because i have such a huge weight of ice in the back its already lower!
good luck and email/respond with any questions
riclemus
Springs
The best is to use Eibach, Sparco or OMP with 30mm lowering. I am using B&G coils, about 40mm lowered with 205/45R16 tyres. Rear part, no problem, but front part, rubbing the inner plastic cover wheel arch, if riding hard on a bumppy road. So, the best is to go for 30mm and you will be saved.
Regards,
Syed.
but..
but..i don't want to be saved, i want my bravo to look mean :D
I'll see ;)
I'm getting my 17's and 205/40/17 this or the next week and now I already have Apex springs (35mm) and if it will look poor, I'll change them.
thanx for the info though ;)
Wheels
Wow Syed,
How's the ride of your car? Not to stiff I hope.
Cheers.
70mm...I'm on -80mm
Hi, I am on -80mm at front for the moment...
This combined with Novitec shocks which i turned on the hardest...
I drive my original bumper+ms design front...
Sometimes I touch the ground, but no furthers probs however...
It is just a matter of getting justed to it, and to take in account that some parking places etc are not possible anymore..thats all...
80mm drop? huh
what alloys do you have on? 15"? 16"? 17"?
thanks
Lowering Springs
Gurjit,
I am using Coupe 16" 20VT rims with 205/45R16 tyres. I have to changed back to original springs at the front to avoid wheel touching the arch. But at the back still maintain the lowered springs. Comfort wise, the same. Maybe because the KONI shocks doing its bests.
Regards,
Syed.
M
4
376
M
A
341
allan
A
A
20
298
G-Man
G
R
4
365
Robin
R
