HiHi,
hello to all,
I have started having a problem with 5th gear it has started throwing itself into neutral are there any obvious reasons for this or anything a can check to solve it or is it a bit more sinister!!
regards
1999 Ducato.
Having just driven Motor home around Normandy and back to Scotland in 4th gear ( yes it started jumping out not far from Calais) its now time to get 5th gear/synchromesh fixed.
Off to gearbox specialists on Monday. I am told parts hard to get. Can any one suggest supplier?![]()
As I said in previous post it was 2005 the last time I got a 5th gear set and I picked it up in Poole from Fiat Dealer on my way back to Scotland.
I wouldn't go for a 6 speed box as the gearing would be too low for the constant 3500kg weight but the newer 5 speed box from the later model is a straight swap and the gears are all in the box, not the bolt on overdrive you have at the moment.
Best of luck.
Krosus- when did they change this setup? I have an 05, and would maybe like the higher top gear everyone moans about as being too high. Tho' me moho is 5.2 t loaded, thatt may be TOO high, but it feels stressed on the Mway over 60- but will do 80+ if asked.
However, it would have to be an easy-ish swap!
Hi, I don't understand the question, but I'll give you info and you maybe be able to fathom out your answer. I've a motorhome on a Ducato 2.8jtd chassis, 5 gear box, weight rating at 4200kgs. No remap of ECU. This rig struggles in 5th gear up slight inclines and annoys the hell out of the cruise control, I feel that if the ratio was lower everything would be fine, obviously for steeper inclines a lower gear would be required but for motorways at 70 it's smooth and relatively quiet in 5th, it certainly never feels or sounds like it needs another gear, unlike the wife's Mx5.
I think that a 6 speed box would just increase this problem as power to weight ratio would be insufficient to maintain a decent constant speed.
Hope this helps
Sent from my iPhone using FIAT Forum
