Technical 40mm Tricker TB Specifications
Dartford
As I had my 40mm Tricker TB off for sale I though I would take dimensions incase anyone would like to make copies for other people on the forum or themselves. The measurements I took are below;
General Throttle Body Details
- The sleeve is completely flush with the face of the underside of the TB.
- There are four semi-circular slots filed into the underside of the sleeve as pictured.
- The two semi-circles in the end with the single pipe connection (sits towards the front of the car when fitted) measure;
- Width across top of semi-circle; 13.50mm
- Depth to centre of semi-circle from top; 5.45mm
- The semi-circle in the smaller of the chambers at the back of the TB measures;
- Width across top of semi-circle; 7.20mm
- Depth to centre of semi-circle from top; 2.15mm
- The semi-circle in the larger of the chambers at the back of the TB measures;
- Width across top of semi-circle; 12.50mm
- Depth to centre of semi-circle from top; 4.12mm
The spacer
- External diameter; 79.71mm
- Internal diameter; 39.97mm
- Thickness; 19.30mm
- Hole diameter (x2) 6.80mm
- Distance between holes; 63.50mm (approx, should match holes in TB)
The Gaskets (2 x sit either side of ally spacer)
- Thickness; 0.80mm (I assume most gasket paper can be used)
Throttle body Sleeve
- External diameter; 42.35mm
- Internal diameter; 39.95mm
- Sleeve wall thickness; 1.20mm
- Length; 32.85mm
Regards,
Matt C
