http://cgi.ebay.co.uk/2K-clearcoat-lacquer-aerosol-car-paint-NEW-Technology_W0QQitemZ8072048158QQihZ019QQcategoryZ30923QQssPageNameZWD1VQQrdZ1QQcmdZViewItem
this stuff is superb! it came up a while ago on here with people asking if its anygood. I think im the only person that bothered to buy some
Its great! seriously! you dont get a massive ammount in a can (400ml i think, enough to do a coat on a spoiler/side skirt etc) but its superb! Sounds a bit dodgy at first but it really is what it says and is well worth the money!
no need to mix it or use a compressor or clean the spray gun etc cause you just throw it away once youve finished and its just as good too! the spray cap has a slit rather than a hole so you get a proper spray rather than a random one like on the halfrauds cans. plus inside its proper 2K paint so you get a perfect bodyshop finish (provided youve preped the surface properly) which isnt nasty and thin like what you would get out of 1k lacquer (halfrauds). plus it can be polished up afterwards if you make any mistakes unlike halfrauds lacquer.
Basicly the can has 2 continers inside, one with the 2k lacquer and the other with the activator. when your ready to use it, you press a button on the bottom of the can which breaks a seal between the 2 containers and they mix to create the 2k lacquer mix.
You shake it for 2 mins or so and off you go just like a halfrauds can!
ideal if your just spraying something small (spoiler for example) but obviously not idea for spraying larger objects as it will run out before you get a chance to finish
Seriously, get some!
