Technical 2016 500X New member new issues 😆
Dadscabs1
United Kingdom
Hi all I'm a newbie here but I'm assuming probably an old issue a few here may be familiar with,
My daughter's car (2016 500X 1.4 multi) had cut on her the other day and wouldn't start so she left it and walked the half mile home, when returning later it started so drove it home only to have it fail to start later on that evening but this time it was doing the whirring noise of a failed starter so we had a friend of ours called over replace the starter and since then have had no start at all on the car no dash lights or anything now our friend is a competent mechanic constantly rebuilding engines on most major manufacturers but as he admits himself electrics is not his forte but suspects it's either the connection on the negative battery terminal or possibly the BCM my question is anybody on here aware of how we can test these components before replacing as they're not the cheapest things to replace on a whim?
Also I have posted an image of the codes regarding this:
Sounds like it could be a power supply issue.
Has a substitute battery been tried?
Run a jump lead from battery negative to clean metal on the engine block to provide a secondary earth, to confirm it's not an earthing issue
Hi just a quick update battery was replaced as was needed anyway and the culprit to our nightmare was a 20 cube fuse under the battery fuse compartment thanks for the info though 👍
