Hi, the horn stopped working so I've checked the following:
Fuse ok, relay removed and checked ok.
Power in Fuse box relay terminals.
Direct 12v makes horn work.
Airbag removed and power at horn connection to airbag module.
Power before and after clock spring.
When sending power to relay from steering wiring I only have 11.5v at relay switching terminal but 12.6v at relay battery feed terminal. Should 11.5v be enough to operate relay? Trying to track where voltage loss could be. Fuse box disconnected, removed & checked but no obvious corrosion there. HELP! Getting to stage of running cables through bulkhead to separate dash mounted button
