Hi all please can you help? I have an over active ABS pump that seems to activate regardless. I have read the ecm fault codes and theyre are non. The ABS warning light does not come on. But does come on when the ignition is turned on then goes off once it has done a system check. I have tried by replacing the front discs and pads plus I have pressure bled the front and rear brakes. I now have an amazing brake pedal however the ABS pump does come on when moving slow in traffic causing the pedal to judder. I have also tried removing the multi plug from the ABS ecm to see if there is any damp or corrosion on the pins.. Any idea will be concidered.
Many thanks
Tony31
Many thanks
Tony31
