F Fatkev007 New member Joined Jan 5, 2013 Messages 14 Points 8 Mar 6, 2013 #1 Hi we got 2.8 jtd 2004 camper ,and want to do the cam belt ,but don't no what the horsepower is ,how do I find out thanks
M moodrater Member Joined Dec 15, 2011 Messages 727 Points 129 Location omagh Mar 7, 2013 #2 Its on your v5c max net power in kw its wither 93kw or 107kw. As far as I know the timing belt kit is the same for both anyway: gates K015334XS without tensioner, K025334XS with tensioner. http://www.gatesautocat.com/article/K015334XS http://www.gatesautocat.com/article/K025334XS Great prices on belts online: http://www.ebay.de/itm/Zahnriemensa...931831617?pt=DE_Autoteile&hash=item19d40d6b41 This post contains affiliate links which may earn a commission at no additional cost to you.
F fenman New member Joined Sep 15, 2011 Messages 132 Points 21 Mar 7, 2013 #3 .....and if you want it in HP just divide by 746, e.g. 93,000/746=125 (approx)
OP OP F Fatkev007 New member Joined Jan 5, 2013 Messages 14 Points 8 Mar 7, 2013 #4 Just looked on the log book and its got nothing where max net power kw is
M moodrater Member Joined Dec 15, 2011 Messages 727 Points 129 Location omagh Mar 7, 2013 #5 Whats your vin. The higher power version has a garret vnt turbo controlled by a boost control valve: http://en.turbolader.net/Turbocharger-Catalogue/8900-1607/0375K6/750510-5001S.aspx The lower power version has a mitsubishi turbo with a wastegate: http://en.turbolader.net/Turbocharger-Catalogue/8900-1131/500364493/53039880081.aspx
OP OP F Fatkev007 New member Joined Jan 5, 2013 Messages 14 Points 8 Mar 7, 2013 #6 Zfa24400007326669
M moodrater Member Joined Dec 15, 2011 Messages 727 Points 129 Location omagh Mar 7, 2013 #7 M15 engine - 125hp Timing belt fiat number 99456476 Gates number 5334xs belt kits as above.
OP OP F Fatkev007 New member Joined Jan 5, 2013 Messages 14 Points 8 Mar 8, 2013 #8 Thanks for your help moodrater
