General  1997 ducato motorhome
Djkc2020
I'm looking for the under radiator panel for Ducati motor home 1997/8. It has 3 large bolt fixings either side. Can anyone suggest where I might get hold of one?
Hi, It's called a front crossmember and I bought my last one from Coastal Motorhomes. I've dealt with this company several times. Good value, great service. All the Best, Ian.
Hi again, Checked on Coastal Motorhomes web site after posting first reply and they are out of stock. Saw a company on amazon who had 4 in stock at £75 but I have no knowledge of dealing with amazon so you'll have to do your own research I'm afraid. Best of luck, Ian.
The bolts are going into weldnuts inside the chassis member it's common for these to twist off when trying to remove the crossmember if you usea breaker bar. There is a hole in the chassis member you can spray penetrating oil into, do that a couple of times in the days before removing and use an impact if possible when removing.
Thanks clifford59 and corcai. really appreciate your help. I'll let you know how I get on.
I've just looked at the e-bay site, they don't have any in stock. I have ordered the same part from "auto doc" should arrive on Friday. they do have some in stock
