General 1984 Uno found
Wow! Shame they're so far away (from Watford) though that might be a good thing as I have too many projects as it is.
The red 'A' reg Uno 45 mk1 looked like a minter and only had 30K on the clock too. Probably only needs a tailgate, o/s rear light and rear bumper to make it good again. A shame it will probably be crushed eventually :(
The peppermint green 'F' plate 45 looked pretty sound at 100k miles, and could be put back on the road with just a rear light unit. Rear o/s 3/4 panel would need serious work and ideally a new tailgate is needed to make perfect.
The red 'G' reg 45 looks a bit rough. Both doors have gone badly as has the bonnet and there's a lot of ripples on the o/s bodywork. Only 77K miles but looks worse condition to the green mk1 that had higher miles!
The white 'K' reg 5 door mk2 looks quite good condition though needs a lot of the front end replaced.
The white 'J' reg 3 door mk2 looks quite sound. Rusty passenger door and needs ignition lock and stuff but otherwise not bad.
And most surprisingly they are all 903cc Uno 45's! Maybe the lack of power hasn't stressed the shells enough to cause them to rust badly ;) I very much doubt I will see that many Unos in one breakers again though :cry:
LOL! Aren't you guys talking these days :D
What's even more indirect than txting each other... or emailing each other... leaving a message on a thread started by the other!
-Alex
No point in bothering him with something so un important at work:rolleyes:
