paulweller84
- Joined
- Oct 1, 2009
- Messages
- 4
- Points
- 2
Has anyone put 18" Schumacher alloys on a 1.2 Active? I've heard i can lead to problems with driveshafts etc later on, is this generally true?
I've been offered a set of graphite coloured rims with nearly new tyres for £350. Don't want to pass that up! If 17"s are no problem I think I should be OK. Thanks
That's increased un-sprung weight and that's bad for any suspension systemI have to admit I was shocked at how heavy alloys are now, my 17" claws weigh a good bit more than the 15" steelies I took off the car! And as for them i've done 40,000miles with the Claws and no failed driveshafts. Not sure how much heavier the 18"s are!
Sure, the motor may look good but it's very likely you've reduced your car's cornering ability somewhat when on less than perfect surfaces.
only prob i've had with my 1.2 on 7.5 x 18's it i bent a drive but that was no fault of the 18's i hit a badger and threw the shaft out of balance. i get my Kumho 711's for £65 a corner and they are a brilliant gripping tyre. i've had no probs with the speedo being out either its still within 10% error so its legal
my alloys are 4x100 Kahn RSC's ET42 offset - using wobbly bolts
Point to remember though is these alloys on the Schumacher were fitted as part of a balanced package (and the Schuey had a significantly uprated suspension).there you go so you should be very much ok with the Schuey 18s
Can't see any problems on motorways and other good roads but you're almost certain to notice fall off of grip on poor surfaces. The best rubber in the world wont do you any good unless it's in contact with the road surface!
I've had my 17s fitted since early 2005 I think, never had a driveshaft issue, although have needed both front springs and drop links doing.... I put that in majority part down to the huge number of speed bumps where I live.
Well if you can afford 18's and the tyres then some new driveshafts now and then is no biggie lol.
The thing is if he puts cheap ass 18" tyres then they may well grip less than expensive 15" tyres! Contact patch is important yes, but so are grip characteristics!
Unsprung weight is the biggest problem, not gearing! If he fitts 18"s then he'll have to fit lower rolling profile tyres, and ultimately the rollowing radius will be the same as the 17's or for that matter 15's!![]()
