hi all, i need some help, i've got a problem with a 2.0 16v non turbo, its got a intermittant knockin noise coming from the top end it is quite mechanical interference noise. It has had a new inlet cam fitted as the 2nd lobe on number 1 cylinder had worn away, so i fitted a new cam and shim to that valve, my problem is the noise is still there!!! it has good oil pressure 3 bar till warm then 2.5. can anybody please point me in the right direction.
thanks in advance
joe
thanks in advance
joe
