Technical  150Mjet Issues help please!
Bravo150tjet
Hi everyone, recently bought a 2008 1.4 150 M-Jet with 90k miles. Has had oil and filter service and timing belt with water-pump done. Few issues need to e resolved and would greatly appreciate your advice and experience with the bravos as the local garage doesn't seem sure.
Had climate control issue with the actuators which has been resolved with the CC working as it should (still hear some whirring in passenger footwell but it works so is fine).
However as part of the climate control fix, the air conditioning pressure switch was replaced as it physically broke off. Since that was put in the engine fan goes on max speed once car is turned on and the thing sounds like a jet engine!
Additionally, the steering has a little it of play in it which wouldn't be an issue for the substantial rubbing noise when steering wheel is turned at start. Once you are turning it it stops.
Also when going at over 55mph, the car begins to vibrate feeling it through the seat mostly. Potentially could be wheel balance but shop not sure will investigate.
Thank you for taking the time to read and hopefully offer some advice!
