Technical  15" wheels! maybe
mechanic80
Perhaps someone who is better versed in fitment of wheels can tell me if this wheel will "fit" the 124 Spider. Look at the Dorman 939-248 wheel specs and you'll see that it's remarkably close to original specifications for the 124 with the exception of a single mm in each direction of bolt pattern and a single mm larger wheel bore. I believe the 40mm offset would be acceptable. Please chime in as this can be a solution to a real problem, not to mention the specialty price if you can even find FIAT aftermarket wheels.
It seems that the 1mm makes all the difference in the world! I doubt that this'll work. Besides, the necessary adapter would add stresses that are certainly not optimal.
