For the sub main power, you'll need to run a large cable directly from the battery. (protected with a fuse at the battery end)
I don't know what that cable is that you found in the boot, however, if this is a switched live (ie, comes live with the ignition), then there's no reason why you shouldnt be able to tap this for the trigger.
