1.6 16v induction kit + Audio Question
O
Ollie
Right as the title says im after a induction kit for my 1.6 where can i get one of these new and for how much .
Right another thing the car has a very good and loud system . ive got a 6 channel jl audio amp running a 12" sub ( cant remember the make) what happens is the sub works for about 30 seconds when the car starts up and then stops working for about 5 hours! whats going on! Cheers !
No inductions kits (or at least none that are any good or that fit) are available for the 1.6.
I'm guessing your amp is going into protection for some reason. What model amp do you have and what power wiring size?
Are you running components from it as well?
Re: Re: 1.6 16v induction kit + Audio Question
More than likely something to do with wiring.
Make sure that your using correct guage cable, and that your headunit is connected straight to the battery!
As for the earthing, where have you earthed your system to?
you can get an induction kit for your 1.6 k+n do a 57i
kit for around 70 brick. if you manage to get one when you come to fit it make sure you take out the box in the wheel arch you'll have to take your wheel off to do so it's a real ball ache but once you've done that the results are impresive
I
1
1K
K
M
7K
M
E
1K
E
I
1
6K
stevew
S
