If I had to describe the sound of my wee 1.3MJ I’d say it is a slightly agricultural sounding engine. It’s done 50000 miles so fairly young, but suspect the timing chain needs replacing as there is a tinkly type of rattle as just applying some throttle from idle, worse when cold.
Secondary to that is a more solid sounding top end rattle when applying the throttle it gets much louder. Sounds like an old fashioned diesel, hence the agricultural description. If it were petrol you’d say it had a serious need for tapper adjustment.
I suspect the oil is a little old, so will replace (with the right spec oil) when doing timing chain. Question is whether it is worth using any additives in this engine?
Back in the day I’d have put Slick 50 in my cars once a year but slipped out of that habit over a decade ago now…
