1.2 Issues...
1.2 Issues...
S
Sean Round
Hi All!
Hoping you guys can help yet again!
Got a bit of a problem with my 1.2 SX atm...
It appears there is some kind of exhaust related issue as it sounds a bit raspy on idle, and when you lie under the car. However, if you lift then bonnet, there is some kind of constant hissing sound, coming from somewhere around the inlet manifold area?!
Anyone have any suggestions?
Cheers,
Sean
hissing? could be you have an air leak in 1 of your pipes or you could have a slight blow from the exhaust.Spray wd40 onto your water pipes and check for bubbles,Also onto your manifold to see if its slightly blowing.
A Fiat Marea in a Bravo Shell :)
Car Status: 23/02/10 - Heating and correct Oil amount sorted :)ready for MOT
P
3
918
paull
P
W
927
wakka
W
I
2
1K
Dark Lurker
