hi i heard online that you can use the 1.2 engine with the 1.1 head (because the valves are bigger or sumit) and the 1.2 camshaft? will this work and what bhp/torque will it produce like this? thanks
1.2 with the punto 75 cam. also the punto 75 head is "said" (i never compaired myself as i keep forgetting to check when the head is off) to have larger (intake) valves.
well i think its just the head gasket has gone but i dont no untill i take it out and have a look tbh.What state is your current engine in?
SPD
Figures won't be much different from the Punto 75. On MPI cars, use Punto 75 head and cam, Sei inlet mani, on SPI cars, 1242 block, 1108 head and P75 cam. Note that the valve clearances will need to be re-set for the P75 cam.
Pretty much all in the FAQ/HowTo.
what are the different engine codes on a punto 60 and a punto 75 and will my 1.1 ecu run the 75 because i know it will run the 60? thanks
