Two days ago I replaced the timing belt and tensioner (disintegrated causing the whole problem) which went easier than expected thanks to the numerous articles on this forum.
The engine is running well and pulls well and still feels quite zippy. However it seems marginally less responsive than before the change. The engine seems quieter and "more refined" now than it was before. The difference is not huge and somebody who hadn't driven it before I changed the belt probably wouldn't notice anything amiss but because I know the car well I can feel it.
When I got the car from my son a couple of years ago he had just had the head gasket done at a garage when it over heated and so it could have been put back slightly different from how I did it following the advice here.
Does the engine need to be timed with a timing light or does setting it on TDC on the flywheel suffice?
I'm in Johannesburg, South Africa and at an altitude of 1800m (approx 6700feet) above sea level and at this altitude I've always been told to set a vehicle's timing about 3 degrees more advanced. I've always done this on my other vehicles that are more basic in having a carb rather than the more complex electronic system fuel injection with all this sensors etc like on the Fiat.
