This came up in the Barchetta forum and is better off here:
Please also see: https://www.fiatforum.com/tech-talk/354006-waterless-coolant.html. This dates back to 2014.
More recently ("B") Forum we have had:
KC3 - May i ask ? whats your thoughts with a water less liquid fluid for the radiator and cooling system?
S130 - I don't have any experience of waterless fluid for the cooling. What I read a while ago is that it is not a straight forward drain and refill exercise to change.
I guess if everything is carefully done "to the book" then the documented benefits appear attractive.
This article may interest you: https://www.pwmag.com/fleets/waterle...nal-coolants_o
If I were doing a complete engine removal and cooling system strip down with new water pump etc. then I would certainly consider waterless cooling as the extra cost and time investment is offset by all the other work being done.
A factor/point I would say is the a traditional water cooling system (preferably with distilled/de-ionised water) with well maintain and quality anti-freeze (change every 2 or 5 years for type of fluid) does exactly what it is supposed to do, corrosion will be mininal and the engines will normaly fail at 100,000s of miles due to basic mechanical wear as opposed to corrosion or overheating damage.
NSMG - Thank you both for your extensive replies.
I have Evans waterless fluid in my car and no problems so far up to now.
It has been 6 months since it was put in. The procedure is quite simple.
There is a washing fluid which basically cleans the system and absorbs the remains of the old water-based fluid and has to be filled in the system and then flushed all out, prior to top up with the definitive waterless fluid.
p.s : KC3, you have PM !
Best Regards
Best Regards
