FIAT Auto Specialist Team
Old 31-12-2010   #1
1999 fiat scudo 1.9 td non starting
during this very cold spell my scudo refused to start ,the glow plug warning light went off and was replaced by a stop signal and the orange fuel injection management fault light , i have checked the earth and they are fine ,, fuel is getting to the pump but no further help please ,,i have tried towing it but its deffo a fuel problem and wunt run ,, i have bled the condense valve and reprimed the rubber bottle fuel is ok not waxed
hillwalker1958 is offline Reply With Quote Quote
Old 31-12-2010   #2
Re: 1999 fiat scudo 1.9 td non starting
check each glow plug should measure 0.9 ohms each disconnected between tip and body
fronteraowners.org admin
fronteratech is offline Reply With Quote Quote
Old 01-01-2011   #3
is it possible all 4 glow plugs have failed? are these seperately fused as i can find nothing relating to them in the vehicle handbook ,,thanks
Old 01-01-2011   #4
Quote Originally Posted by hillwalker1958 View Post
not likely all failed could be control system check fuses
guides here https://www.fiatforum.com/downloads.php?do=cat&id=22
Old 03-01-2011   #5
-~Moderator~-
a1ant's Avatar
Trader Rating: 1
a1ant has donated!
Hi mate,
Highly unlikely to be a problem with the glow plugs. You have said there is no fuel getting past the pump... how did you check this, did you do a leak off test?
If indeed there is no fuel getting past the pump, then its likely that the stop solonoid is sticking on the HP fuel pump. This is somwhat common. IS there any other warnings on? Such as "code"
Alan
If you see a problem post, please click the report button
a1ant is offline Reply With Quote Quote
Old 04-01-2011   #6
we disconnected 2 injectors and no 2 had no fuel coming from it there is a warning light coming on ,, the amber check system, which comes on wen ther is a failurein the fuel feed /ignition system
Old 04-01-2011   #7
we tried reading the code using a bosch reader but it seemed to lock out on us ,, we wer getting no response
Old 05-01-2011   #8
is ther anyway we can check this stop solinoid , and if it is the problem ,can it be purchased independently from the fuel pump ,,thx alan
Old 07-01-2011   #9
alan think the solenoid is available from www.dieselbob.co.uk
Old 08-01-2011   #10
ty frontera for the site address,, i am looking at it just now ,hopefully with all the imput from here i will get it running ,appreciate your advice ,, thx again ,, cheers..alan
Old 10-01-2011   #11
ahhhh one last thing , jeez i feel like inspector cluso here ,,if the stop soleniod on the pump is faulty ,,is the ecu clever enough to put out the glow plug lights ,and put on the amber fuel fault management light ,i guess im just trying to make a decent guess that the fault is not in the ecu ,,thx again ,,alan
Old 10-01-2011   #12
some stop solenoids you can test by removing the plunger from them then refitting. the engine should start but you'd need to stall it to get it to stop if it is the solenoid thats the problem. Are you actually getting 12v to the solenoid?
petrolhead69 is offline Reply With Quote Quote
Old 11-01-2011   #13
good question ..ill check that ,, thx
Old 11-01-2011   #14
-~Moderator~-
a1ant's Avatar
Trader Rating: 1
a1ant has donated!
Hi mate,
Just another quick thing to add... have you tried resetting the emergency fuel cut off switch?
Alan
Old 19-01-2011   #15
ahhhhhhhhhhhh a twist to the tale ..mechanic has now checked everything ,, glow plugs fine fuel getting to everywhere it shud now ,butttttttttttttttcar is misfiring , holding back ,, he feels when we had the -17 temp freeze up and i had tried to start the scudo it has slipped
a couple of teeth on the timing and now he is going to remove casing and check ..ill keep update d,,thx everyone
(T) Scudo still not starting seker Scudo 0 12-03-2010 13:00
(G) scudo starting problem jbeany1 Scudo 2 14-07-2009 18:39
(T) Scudo Starting Problem Help kenny70 Scudo 5 29-04-2009 20:00
(G) none starting scudo schummy10 Scudo 3 19-07-2007 22:12
(T) starting problem punto 60sx-1999 sps Punto (Mk1) 2 12-11-2006 13:09
