Old 16-05-2012   #1
Greece
how to retension sunroof blind spring
I am trying to retension the spring of the sunroof blind.
I have removed the headliner and detached the rear part of the blind.
I turn anticlockwise the spring (using a flat tool as a screwdriver) but when
I try to mount it back to its place (using my fingers or pliers to keep it tensioned) I always loose grip and the spring unwinds.
Any suggestions about the correct procedure to follow?
velissariouc is offline Reply With Quote Quote
Old 19-05-2012   #2
Greece
Re: how to retension sunroof blind spring
This is how to prevent the spring of loosing its tension again:
I have added the nut to act as a spacer and prohibit the blind moving too far to this side.
If this happens then the spring lock which is located to the opposite side, is released and the blind looses its tension.
And here is my unsuccessful attempt to wind the spring
Likes Shadeyman, Davren liked this post
Old 19-05-2012   #3
Greece
Problem solved!
There are two slots at the end of blind.
When the slots are aligned a pin can be inserted to keep the spring from unwinding.
The pin must go through the hole and when the blind is secured the pin is removed. It is preferable that the pin is I-shaped instead of L-shape (like the one I used)
Likes Shadeyman liked this post
Old 21-05-2012   #4
Greece
velis any parts left from fixing your sunroof? :P
1.6 silver dynamic 3d with skywindow, Schumacher Look, Abarth Pedals,Brembo Brakes,Bilstein Eibach Suspension, Eagle F1 Tires, K&N Filter,Sport Steering Wheel,Sport Knob,3M tint.Philips New Vision Lights. Founder & Admin of the Greek Stilo club www.stiloclub.gr
Stilatos is offline Reply With Quote Quote
Old 21-05-2012   #5
Greece
hi stilatos,
I didn't replace any part, so I don't have any spare parts.
(T) Sunroof jammed & sun blind went "blind"... ucetincan Stilo 0 23-05-2009 17:53
(G) Sunroof for the spring? Pandarus Panda (Classic) 5 05-01-2006 21:58
