FIAT Auto Specialist Team
Thread Tools
Old 09-03-2010   #1
speed pulse / abs system wire location
hi,
i've got a problem witch is my aftermarket HU requiring a speed pulse signal witch can be located in a fusebox area position 7 or 10 white/purple or green/white or blue/white wires as i found out, can some1 tell me what are these wires transmitting? as i dont want to screw something up that later will cost me loads to repair...
i've got a few images with the connector and the wire loom pointed with red arrows
cheers
ID:	74926   Click image for larger version
x3me is offline Reply With Quote Quote
Old 10-03-2010   #2
It's about GO! not SHOW!
Argonought's Avatar
Argonought has donated!
Re: speed pulse / abs system wire location
What pulse are you looking for
OEM HU receives speed info (for auto volume) via the CAN network.
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: FALKEN ZIEX ZE912; Oil: Mobil 1 TD 0W-40 fully synthetic
Argonought is offline Reply With Quote Quote
Old 10-03-2010   #3
Trader Rating: 2
danhans115 has donated!
Andorra
For an aftermarket sat-nav head-unit, but without using CAN as the signal converters are very expensive.
If it aint broke, break it and fix it anyway
Former Abarth Owner
danhans115 is offline Reply With Quote Quote
Old 10-03-2010   #4
Quote Originally Posted by danhans115 View Post
Can't do on a stilo.
You need to buy a CAN to signal converter. Vehicle speed is calculated by the ABS unit, based on the average of two of the wheel speed sensors. It then transmits it over the CAN bus to instrument cluster / radio etc.
When I got my stilo, it had one fitted, for something that had been removed by the previous owner. I threw it away over a year ago. Oops!
john55 is offline Reply With Quote Quote
Old 10-03-2010   #5
12[X] has donated!
the op could back probe the actual sensor.. an electronic converter for that would not be as dear (assuming the HU needs one at all)
12[X] is offline Reply With Quote Quote
Old 10-03-2010   #6
Quote Originally Posted by 12[X] View Post
The sensor does not put out wheel speed. It puts out something like wheel speed * 50 or however many teeth there on the reluctor ring.
Old 11-03-2010   #7
Quote Originally Posted by john55 View Post
well they are from about 50 on ebay going to about 80 as i noticed so you should have considered keeping it. but the thing is that i've been told by a bloke in the avicx1 forum(pioneer avicx1bt is the HU in the car) that it's them positions on the cable witch is in pic 1 for getting a speed pulse, i'm not sure it might take the abs signal, but i just need to know where to look for it
as i just dont want to spend 50 on a plastic box that i dont need...
well there's not much of an option if there isnt one...
Thread Tools
speed pulse wire x3me I.C.E 0 09-11-2008 19:13
(T) Speed Pulse location neilnitro Punto (Mk2/2b) 6 30-08-2006 18:16
(G) Speed Pulse Wire fool2cool Ducato 0 25-04-2006 19:41
(T) speed pulse wire borofan Punto (Mk2/2b) 2 29-10-2005 14:39
(T) Speed Pulse Wire?? Carlo Doblo 1 16-01-2005 19:48
