Hi all.
Have had both headlamps off of my Stilo today. Put the nightbraker bulbs in and as headlamp motors were both US'ed I canabalised the motors from a defunct set of headlamps from my sisters 2004 Panda that use the same motors.
Got the motors switched, and they work great (will come in handy when I've a full car load).
Have refitted units to car and everything and I've had to adjust the level of both units manualy as the were way to low.
I've now got them at a ok level (still slightly to low), but the beam pattern doesn't seem right (although not in a way thats dazzling oncoming people). The beam pattern has never seemed right on my Stilo for the record. Left (N/S) headlamp seems very direct, and O/S lamps seems better but not perfect.
So questions and favours time.
Questions, the knoobs on the back of the headlamps, I'm assuming one adjusts height and the other pattern? Ones nearest rad on both units seems to do height, so I'm assuming the other (almost under the wing) does the beam pattern, or does this also do the height at the other end of the unit (as they are long units in compairson to some).
Favours. Could some members please take a pic of their headlamps (dipped beam) on and pointing against a wall from a distance of about 10meters please? I want to see what your beams look like. Doesn't matter if you've a LHD Stilo, as they'll just be beams pointing the other way.
Many thanks in advanced
Jon.
P.s, I'm fully aware that adjustment of the beam pattern needs doing properly, but I'm just want to see if mine are actually wrong, and if the other adjuster does the pattern or if I can use it also to raise the level slightly more and evenly.
Jon.
