swansea2007
Member
Hey guys Taken my car to the garage and they need to replace the crank shaft Pulley as the rubber inside has screwed up. All it does really is just makes an agrivating noise. What other problems can this cause?
I had this a couple of years ago (less than a year old). Rattle drove me mad. Not sure what damage it could do though.
It will fall off soon, smashing the plastic cam belt cover and jamming or snapping the cam belt. i.e. you will need a new engine if you do not change it. I personally would not drive the car if I was you until it is fixed, as it is very expensive to repair if it does break.Hey guys Taken my car to the garage and they need to replace the crank shaft Pulley as the rubber inside has screwed up. All it does really is just makes an agrivating noise. What other problems can this cause?
Apparently a recall issue iirc http://www.vosa.gov.uk/vosa/apps/re...97B534BE25A00E802572660035DF0A&freeText=Blank
Hmm shall i take it to fiat or shall i leave the garage do it as its Still under warrantie
Take it to a Fiat dealer 1st and see if there is an outstanding recall on your car, if not and your not going to get it done as a recall, then take it to the place that will do it under warranty
Recall was only on 1.1, 1.2 & 1.4 8v and 16v engines- NOT the 1.6 16v as owned by swansea2007.
I have a question... did the rattle go when the weather was warm? Mine rattles but only when the engine is cold... if the temp is above 20 degrees theres no rattle at all, but takes a long time to settle on a cold day.
