mikeh
Abarth Cambelt change - to DIY or not??
My Abarth has done 68k now (only had it 2 weeks - had a shade over 67k) and a quick inspection gave no clues as to it having had a new belt at any point so I think I'd better get it done.
So the big question is can you do it yourself without the special tools to undo the cam wheels and without the jigs to hold the cams in the right position?
I understand that doing it as per the manual will ensure correct valve timing but if you get an independant garage (and possibly some main dealers) to do it, I would be surprised if they didn't just slacken off the moving tensioner, slip of the old belt and put the new one on, check the timing by turning it over by hand a couple of times.........."that'll be £xxx please sir"
I'm more than confident in my ability to change the belt (probably more confident than I am in many 'mechanics' abilities tbh), I'm just not sure how crucial having the special Fiat tools is. If they are essential does anyone know if it's possible to hire or borrow a set?
Any help on this greatly appreciated.
M
M
