Excellent help from Decks there.
This isn't Stilo-specific but I thought I'd state the obvious just in case: as the pads wear down, the fluid level drops by a large amount, I know it IS obvious but it's generally the reason for 'low fluid level' warnings in my FIATs. I don't think I've ever had a false alarm, but maybe the Stilo is different. Of course if you do top it up, then when you change the pads, you have to remember to take some fluid out. So I tend to check the pads before topping-up.
-Alex
