Technical Fiat 15" alloys on punto
puntotash
hampshire
Hi i need some help:
I have a 1996 P reg punto 1.2 75SX. It is running with standard 165/65R/14 wheels and tyres. I have purchased some genuine Fiat 15" coupe wheels (6.5JX15H2-40 speedline which is on the wheels). I have spoken to a tyre dealer and i can use 195/50/15 or 185/55/15 tyres. I know the stud pattern is the same but will i need spacers behind the wheels or will they fit on ok as they are?? The car has not been lowered.
This is my 1st car so help please.
Tash
Hi sorry about the error on the standard wheels (17" i wish)
the only things on the coupe wheels are:
6.5Jx15h2-40 on the front
on the rear of the wheel is:
Italy SL1438
SPEEDLINE
B412
I have measured the distance from the rear of the wheel to the back of the cetre hub (the part that touches the hub on the car) and its 14cm deep.
The internal diameter of the wheel is 36.5cm
Hope this helps.
hi thanks for that
Can i use standard bolts or do i need those wobly things?
I am having some continental 185/55/15 tyres fitted to them later in the week so will let you know. If they do rub what will it be on, so i can look out for it..
cheers
just added a pic of them into my profile so you know what wheels i'm on about. Once/if i get them on I will add a pic.
hi
just found a couple of coupe's on autotrader with the same wheels : 1999/2000 V Reg FIAT Coupe 20V. :D
cheers :p
