fimmo
i have alwyas liked the renault 19 16v bonnet vent from the phase 2 version of the car. i fitted the rgm plastic version to two of my previous xr2's! but recently i was able to get hold of a real vent from a scrapped renault (the real one's are made from metal and are two piece!)
i primed and painted it myself but got my pals at their bodyshop to lacquer it to give it a better shine as tinned lacquer is just a waste of time.
cut the bonnet and fitted it myself within an hour......
the vent sits just behind the k+n so the water that gets in (very very little) just falls down behind the vent,now the vent get's cold air from the vent and the usual pipe that come's with the filter.
my aim was not only to give my induction kit maximum cold air but to try and lower the under bonnet temp. and it work's!!!
usually cinq's run at 90 on the temp gauge bit more in the summer heat but since fitting the vent i run at a very constant 70!!! it only goes above that if i'm sitting in the car at idle speed but once i've started moving again it goes back down!!!
10/10 for function but for some reason i'm not sure the vent suit's the cinq 100 percent??? whatever,it does the job it's supposed to do and now i have an excellent induction noise when i hit the accelerator,you really do hear it sucking the air in!
