Peccadillo
- Jul 5, 2008
- 35
- 8
2002 mk2 1.9D (not JTD)
There is a slight oil leak (a fine spray) coming from the front of the cam box black plastic moulding. Not sure if it`s the actual gasket or the cover itself thats a fine crack under the front.
Anything I should be aware of in this area before I take it off to fit a new gasket?
It seems this cover is also part of the inlet manifold - how do the inlets intakes seal? are they separate gaskets? or O rings that don`t need renewing?
Also what is the device that`s held into the cover by two bolts and running from the silver mesh covered hose?
Are there any breathers that could have blocked and caused this slight oil leak>
By the way, It occurs as a fine oil spray out of the (hidden from view) front base of the cam cover, but only above about 60mph.
That had me thinking about blowback past the rings but the engine doesn`t burn oil and has done 55,000 miles.
Thanks for any advice.
