A few days ago a fault was found at the crank shaft sensor and so the guy at the garage repaired the wiring. But recommened I repace the sensor in the future, if ever the problem re-occurs.
The car was working perfectly for a few days. But only yesterday did it start playing up again. I got out to start the engine and it wouldn't start. I knew straight away it was the crank shaft sensor which had gone.
I thought I'd leave it for a couple of hours. I used the red key this time, and voila ! it fired up, left it running for a minute or so, switched off the engine and used the same key to start up again, but it wouldn't start.......
Well the car has been at the garage today and the mechanic has replaced the sensor but the car will still not fire up. He's check the leads/spark plugs and he suggests there's no spark there somewhere.
He mentioned something about opening up a module....not sure what this is.....can anyone suggest where the fault could lie or what I could do ?
P.S. battery is full, starter motor and alternator perfect.
