Hi, i recently took my engine to bits and had the cylinders horned becaused they were scored. We have replaced one chewed up piston, piston rings, big-end bearings and rebuilt the whole engine along with a 1.1 head as the 1.2 head was to chewed up to be used. We have used a 1.2 gasket and changed the cam to a 1.2 cam. Bolted it all up and tried to start it but it wont run. We re-did the timing and tried again and it almost started but then gave up and since then nothing. However, the car has got bearly any fuel left and the battery is almost dead so we are going to give it some fuel and are re-charging battery but if this has no effect what could be wrong?
We've checked the compression and thats ok, the spark plugs and ht leads are new and they're all sparking.
