Phil
Member
For my Mk.1 75 with 1.2 8V engine.
I'm in the process of replacing the thermostat and in doing so have found the source of the oil leak on my engine;
YUK!
Its coming from the cover of the bearing of the cam shaft, which is also the same casting that the coil packs are mounted to.
It looks like the "O" ring may be the cause of the problem;
Does anyone know the part number or a link to get the "O" ring from (my local dealer would take about 1/2 hour to find this part on the computer system and then I'd have to order it anyway!). Any help muchly appreciated.
YUK!
