barry walmsley
- Feb 21, 2007
- 7
- 3
Can anybody give me some correct info here ??
I'm considering the "best" way to overcome my current "1 blue key only" situation on my daughters Punto 60S; I've contacted a couple of website suppliers :-
• Codeman (Sheffield) whom claim if you send back the working key they can re-programme the ECU & code box and supply 3 new keys (1 red master + 2 blue); alternatively
• Peacock & Purvey (Deryshire) whom sell decoded "free running" ECU's that enables "non coded keys" to be used
I'm a little wary of both the above to spend £200 or so only for either not to work
I understand that with my current "1 blue key only" if we (for instance) get a flat battery the ECU looses it's code and awaits the red key to "unlock" ?? Of course we don't have a red key so this is a problem
To add a little further complication, the main ignition switch barrel itself is a "little problematic"; the sole blue key we have is a bit difficult to get in as though either the barrel or key are slightly worn
What has triggered this query is that after (obviously wrongly) having a standard £5.00 key cut at my local market and finding out this wouldn't turn the ignition (immobiliser lock lamp on dashboard illuminated) the ignition will turn okay maybe every 10 attempts but then "lock" with the immobiliser for maybe 4 or 5 attempts
Trust somebody can shed some useful light on this one
