you have to remove all the screws along the bottom, remove speaker cover use a small flat head screwdriver be careful or you'll break it remove speaker and screws, unscrew and remove door opener surround, back of the mirror there's a small tab remove & undo screw, the card will now only be held on by plastic poppers carefully pull these out screwdriver should help, you should now be able to remove door card, hope this helps
