Hello,
My Punto 1.2 8V is cutting out all of the sudden.
Morning I started and it didn't start.
I repeat this two times, same thing.
Third time it starts, but kept running only about 10 seconds, then cuts out.
I checked with multiecuscsan and there was no any codes.
When it runs all parameters looked ok.
When it is running, it runs normal and cuts out like when you turn the key off.
One time when it cuts out I wait about one hour and I pushed the fuel rail schrader valve and the was a little squirt of fuel. I allways thought that if there is 3 bar of pressure, it squirts a lot of fuel. Then I cycle key one time and again tested schrader valve. Same amount of fuel than previous. Could it be fuel pump issue or Ignition switch?
