Old 16-02-2017   #1
Finland
Unhappy Engine cutting out randomly, happened when engine was both hot and cold
Hi all,
Fresh from having fixed my battery issue...
https://www.fiatforum.com/punto-ii/4...ng-starth.html
... I've now got a random engine cutting out issue.
It's only happened twice so far (but only recently got car going again) once I'd only started driving 2 minutes ago and this morning happened when the engine was fully warmed up.
There is no code light or anything like that which I've seen mentioned elsewhere. I just suddenly notice no power and look down and see the battery and oil (I think) lights on as if I'd stalled it, but today it would have been impossible as I was going about 80 km/h.
I think I've read a couple of posts where people suggest alternator / wiring from battery - alternator issues. Or maybe it could be some sensor or something ?
Would be handy to know what's most likely to get started on.
Cheers,
Paul
PaulTobiasx1/9 is offline Reply With Quote Quote
Old 16-02-2017   #2
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Re: Engine cutting out randomly, happened when engine was both hot and cold
If its been a while since its been running - has it actually got fresh fuel?
Fuel Can and does go off - which can cause running issues
Just ensure the battery connections are yes Clean and tight as well
sudden fault after a battery change - points towards a possible battery issue
ziggy
Thanks deanmiddleton123 thanked for this post
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 16-02-2017   #3
Finland
Quote Originally Posted by Ziggy122 View Post
ziggy
Ziggy,
It's possible the fuel in the bottom of the tank was a bit old as previous owner hardly ever drove it, however I filled up to a full tank only about 1.5 weeks ago so 3/4 of the fuel is new, and mixed with potentially old fuel.
With this in mind maybe a fuel cleaner might be a good start.
The car also doesn't particularly like decelerating, quite juddery especially with low revs.
Regarding the battery it's brand new and was already charged when bought. I had a go at trying to clean up the battery terminals when I installed it but haven't touched anything on the alternator or starter motor as hard to get to.
I also tried to tighten the alternator belt by moving the alternator on it's adjustment bolt, so maybe I did it too tight ?
Cheers,
Paul
Old 16-02-2017   #4
Quote Originally Posted by PaulTobiasx1/9 View Post
Ziggy,
Cheers,
Paul
Clean the throttle body then
Simply whip airbox off - and using a wrag and some wd40 sprayed onto the wrag, give the butterfly and the body enwhich the butterfly valve moves in a darn good clean
A tooth brush may also help here!
Why?
If the cars hardly driven - it could be a oil/moisture blocking up the butterfly valve in the throttle body - its a maintenance thing really - should be cleaned every 30K - 50K idearly
If you ever have air filter off - its a 30second wipe around and helps prevent Jerky De accelerating and could be the cause of it stalling randomly (struggling to breath in via the tiny gap of which idle is)
Ziggy
Meet Bumble-Bee
Old 16-02-2017   #5
Finland
Ziggy,
Thanks a lot, will definitely give this a try at the weekend, not attempted such a thing before but sounds doable.
Good to have things to try first that don't cost anything!
Paul
Old 16-02-2017   #6
Ziggy,
Paul
Anybody can do this task! Yeah sure some girlies would moan... but nowt new
its a simple 2x Nut and 1 spring clip
pop airbox off
Stick finger into a hole and rub around
kinda like doing the dish's but just on a car
Ziggy
Likes digger58 liked this post
Meet Bumble-Bee
Old 18-02-2017   #7
Finland
Why?
Ziggy
Hey Ziggy,
Just had a go at this, it wasn't exceptionally dirty, but definitely a bit of black crud around the edge which I attempted to remove.
Whilst doing the clean I noticed some botch type repair job on one of the tubes connected nearby...
What is this ? Could it another potential source of juddering / engine cut-out ?
Cheers,
Paul
Old 18-02-2017   #8
That black crud thats hard to remove usually is the cause
I cant see the image as its not showing as been complete (might be my phone tho)
Ziggy
Meet Bumble-Bee
Old 18-02-2017   #9
Finland
Old 20-02-2017   #10
Finland
Ziggy
https://drive.google.com/open?id=0Bz...EwSHgxelNBQUtz
Ziggy?
Old 21-02-2017   #11
flisko has donated!
thats breather hose
flisko is offline Reply With Quote Quote
Old 22-02-2017   #12
Mine did this a few times before the alternator belt snapped. New belt, no issues. Not sure what relation it had but wouldnt hurt to check
Thanks PaulTobiasx1/9 thanked for this post
HGTGirl is offline Reply With Quote Quote
Old 23-02-2017   #13
That Bit Silvery Bit in the Middle of the Bottom half of your air box
Thats the Throttle Body under there - its a flap that opens as you step on the throttle and snaps shut when you release
In there is where you need to clean
its 10x Easier todo when you remove the 2x 10mm Bolts on the airbox Top left (10 oclock) and bottom right (4ish oclock)
There is also a spring clamp thats on the cam cover (7ish oclock)
When refitting - Dont forget to reattach the Breather hose that simply slides into place under the airbox
If you dont re-attach it - you will end up with hot oily fumes stinkin the joint out
Ziggy
Likes PaulTobiasx1/9 liked this post
Meet Bumble-Bee
Old 23-02-2017   #14
Finland
Ziggy,
I did actually give the throttle body cleaning a go, admittedly didn't undo any further bolts once I'd removed the cover of the airbox though so might have been a half ars**d job.
I feel that it has made a difference, still a bit of judderyness but nowhere near as much, for all I know it's a normal amount of judderyness. Certainly more drivable anyway and no engine cut outs for the short journeys I've been on with it.
With the breather hose thing, I was just wondering if that could also be contributing to the issues, maybe I should try and buy some kind of repair stuff like what has been used previously to fill the cracks ?
Paul
Old 09-03-2017   #15
Finland
Does anyone have anymore ideas on this ?
I'm not keen to spend much more money on this car after wrongly replacing the battery and having to replace the alternator - but, it would make driving much more comfortable as well as having more confidence in the car not breaking down if I could find the cause of the judderyness when backing off the throttle or using close to idle.
I also have something I've seen described elsewhere where when sat a traffic lights at idle the engine 'pulses' maybe it's a slight misfire or something ?
I have the throttle body a good clean and so this can't be causing the issue. I haven't actually had the engine cut out at all this week, and the juddering is possibly (though could be in my head) slightly better so maybe this cleaning at least improved things.
Throttle position sensor ? Spark Plugs ?
Cheers,
Paul
(T) Engine Cutting Out Randomly memson Stilo 1 01-07-2016 07:10
(T) Engine cutting out randomly moschino02 Stilo 3 10-03-2012 16:13
(T) hot engine then cold engine with blowers magicmikey Stilo 1 03-12-2010 08:14
(T) Engine hot, hoses hot, radiator COLD levets Punto (Mk2/2b) 16 13-04-2010 10:40
(T) engine hot, heaters cold craftyfox Cinquecento / Seicento 5 27-09-2009 16:47
