General Punto 1.2 Mk2b Dynamic air-con
RollsRoyce
hello
I saw some adverts about Puntos with air conditioning.
I think all or most of Dynamic FL version have got air con.
My question is where is the air-con switch and indicator that is turned on?
In 1.4 Eleganza there is special air-con computer, so it easy to find out,
but 1.2 Dynamic???
Please tell me. I would like to grab Punto with air-con.
hello
but 1.2 Dynamic???
in the speed control
IIRC you simply pull this out 1 click - there should be alittle light on the speed dial that then lights up :)
So the fan control 0 1 2 3 4 is the object you need
Ziggy
Ziggy
Fan control is for air circulation, so I don't understand your answer
in 100%.
I assume that when air-con is on then on dash board something come up,
but it is only indicator.
All late 2003 - 2006 mk2b dynamics had aircon
The centre fan speed switch has the little snow flake symbol
You push the whole fan speed knob in till it clicks and springs back out and the air con is switched on the little light in the middle of the knob then comes on
